Uni-Lug Rims (Updated - Got the Rims)
Gonzo1970
898
1,302
oval holes = uni-lug, right?
-Gonz
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
possibility 4.5 and 4.75
or drove with loose lug nuts! :p
Gonzo1970
898
1,302
Came off a 1963 Nova. 14x7's with burn-em-up tires... but the price is right.
Hes getting measurements for me in the morning. If it works out, those will be mine. :) :) :) :)
-Gonz
79 USA 1
1,065
2,039
Cheektowaga, New York
-Gonz
Purchased a set brand new in the early 80's for my 61 Olds bubble top.
Fits bolt patterns 4.5 (Mopar, Ford) 4.75 (Most GM) 5.0 (Large Olds, Buick, Pontiac, Full size trucks & Vans)
You will need center drilled washers and lug nuts. (No Offset!)
Ribbedroof
4,903
7,005
Wellston, OK
You'll want the Cragar washers and nuts, not E-T
The Cragrs use a thick chrome washer, E-Ts are way different, and have a recess for the washer
Local Hero
729
1,917
Northcoast, Cleveland, Ohio
All the above is correct. Oval holes are unilug, and you need the correct centered washers and Cragar lug nuts.
The trick is getting them bolted on. I used to have them on my 68 Cougar in the 80s. I would get one started through the hole, then start a second and rotate the wheel around as I was tightening until the lug went through the wheel. Once two are good and started the other three go in super easy.
79 USA 1
1,065
2,039
Should look like these.
Turbolq4
1,732
4,207
Nampa Idaho
Wheel vibration causing unilug shitshow. Guaranteed to make your car drive like a clapped out rickshaw.
fleming442
Captain Tenneal
Dec 26, 2013
13,046
24,216
I didn't have much luck with lug centric wheels on mine. I had put the SS1s off the 67 on the Pig for a hot minute, and it vibrated like crazy as lq4 said. I'm hub cenric on these cars from here on out!
