UPDATED 6/9/22: Ever think one thing for the longest time and then realize it was BS?
#1 makes the most sense, and we were thinking in that line as well, but figured out that it has absolutely nothing to do with top options. That would be, at least in my thinking, the most significant weight changing option. A CC1 or CF5 or a solid top car all had VD6 and VD7 on their SPIDs. It didn't seem to make any difference. So not sure what criteria was used. Was it a Calais/Salon thing? Could have been just whatever was available? And it wasn't specifically the plant. I mean, Lansing used them, Arlington, and Pontiac (86 442s had cars with VD6 and VD7 as well)
But here's the thing... if it had to do in any way with a front vs rear distribution or weight/rating, wouldn't an alteration to the top whether ttops or astro be neutrally weighted due to where they are placed on the car, and where their weight distributes downwards on the frame with a roughly equal share of weight allocating to both front and rear "axle/members" as it were?
Another thought.... any correlation to g80?
The g80 cars had steel drums, otherwise peg legs had aluminum with the reduced rotating mass effect. Would peg leg cars be more likely to get vd6?
Your argument holds true if you use aluminum bumper supports or steel bumper supports front or rear just as well. They're about the same size, so they'd likely cancel each other out.
Total weight above the axles may be a consideration, we just don't know. I know it didn't alter the "computer selected" spring choice much either. I mean, really...95% of 1984 F41 cars came with PZ or SW rear springs, and AFA front springs. There may be others, but these are mostly the ones I've been seeing. Front/rear distribution may have been a factor, but why some had just a front steel and rear aluminum, when others had both the same? I dunno. An odd thing in my small sampling I've seen is that I haven't seen a VD6 without a VD7. Although they did use VD7 without a VD6.
So top option or no top option, it didn't seem to sway the choice of aluminum bars or steel bars by those options alone. So it had to be something else.
Maybe it was some engineer who smoked a little too much of the green stuff. 🙂 Knowing someday we'd be scratching our heads trying to figure out why GM did something the way they did...
My 84 came without G80. My 85 442 has G80. My old gray 85 442 had peg leg. All with front/rear aluminum. Nope. Doesn't seem to correlate. WTF GM?
Yeah I thought I knew everything as a kid going racing!!!!! I'm a drag racer, and growing up racing I tried a lot of different things and I wasted A LOT of money. I admit I tried the flavor of the month magazine dyno parts based on all the claims because I believed I needed them. All I found was they just didn't work at all. Working at an engine builder during this time, I even saw a lot of dyno gains that didn't amount to anything in ET in the car. There were quite a few times the car didn't run the numbers I THOUGHT I was going to. I can tell you how one time I spent a couple 1000, and slowed the car down .15 from a 9.32 to a 9.48. I know I sound grumpy but when somebody tells me that they put parts on that I KNOW only amount to an 8-10 hp gain and they can FEEL an instant difference I just say wow, that's great. I dynoed my 548 inch motor and worked for 23 hp on the dyno. In the car, it went from 9.089 to 9.03. But hey, if you want to spend 100's of dollars on a part that showed 6-10 hp gain in a dyno test, go for it. On the street, it will show nothing and I learned a lot of stuff the HARD way. I don't claim to know everything, but what I do know was learned by wasting money and breaking parts.
I used to think that Tuna Noodle Casserole was pronounced Tuna Nuna Casserole.
I know better now.
Before I joined here I thought half vinyl tops were installed over finished body and paint work since that is how my Monte was when I removed it.
And then the sad discovery of seeing really nice cars on here that had a vinyl and they removed it and the roof was basically gone underneath on an otherwise rust free car.
My 81 was in great shape overall, with a good vinyl top on it. I pulled it off anyway, and it was just starting to rust.
After joining this site I noticed that while I had a factory landau top, I didn’t have landau pillars. Not sure if they stopped the landau b pillars by 81.
They did use the B pillar trim on Landau cars in '81. What you had was the cabriolet vinyl top which is the same but with out the Landau trim/RPO.
