Valley pan gasket
Rocket350olds
Jun 6, 2020
91
48
Does anyone know if it will work to use a valley pan gasket with a olds performer 350 aluminum intake
Oct 14, 2008
8,823
7,775
Melville,Saskatchewan
Yes, used one many times. RTV beads around both sides of the gasket on the 4 water ports. I use about 3 layers high, tall not wider than the rails of RTV in place of the rubber end seals. I also use Aviation sealant, same as Gaskasinch around all the other ports but that is probably not necessary.
Oct 14, 2008
8,823
7,775
No problem, wait overnight before adding antifreeze unless you use an RTV like The Right Stuff. Glad I could help.
