HI need some help here. Been through 3 batteries and 2 Altanator's and im still having problems car charges at 12.3 volts at idle with no volt light on when I drive and step on the gas volt light comes on and after a short drive the battery is down to 10 volts or so. It will charge back to 12.3 or so if I let it idle for a while. Belt's not slipping both alt. And battery were tested good off the car. I'm lost as to why there would be a voltage drop under acceleration. I have not been able to test the voltage at the Altanator wit the car revd up but I assume it's under 12 or I wouldn't be having this problem any help would be appreciated.
