There's a lot of factory wiring in the G Body that can be improved. I made many improvements. I also have a 4 gauge power wire from my alternator (170A CS-144). I also did away with the factory fusible links and installed a fuse hub powered by another 4ga wire.
I upgraded the 2 12+V supply wires to the stock firewall fuse panel with 10ga wire and they are fused at the hub with 40A midi/ami screw-down fuses.
I also have relay circuits powered from the hub for the headlights and dual electric radiator fans. This takes a big load off the headlight switch and the main fuse panel load and helps even further. Notice I do all connections with non-insulated connectors which I crimp and solder. Then cover with heavy- wall adhesive-lined heat shrink tubing.
Dakota wiring:
Here's what's left of my floppy circuit board when I pulled it out. You can see a few places where I soldered jumper wires directly to the copper circuits. Also a few jumper wires that were connected directly to the gauges.
