I just removed the problem solver intake gaskets which allowed the oil to get sucked into the intake ports. I read online that the intake bolts need to be torqued at 35 ft lbs when using the problem solver gaskets so I thought I had made the error of torquing the bolts to 11 ft lbs. I bought some new ARP intake bolts and talked to my friend who owns the speed shop. I asked him about the torque of 35 ft lbs for the problem solver gaskets and he said guys are breaking off the corners of the heads torquing the intake bolts to 35 ft lbs and that the problem solver gaskets need to be torqued to 11 ft lbs. I have the Felpro gaskets with the rubber diaphragm that I will be installing tonight. Apparently with the green coolant that doesn't affect the rubber like the new toxic stuff the current cars use. Any of you guys with the vortec heads have any experience with the problem solver intake gaskets for the vortec heads?
