Well here I am trying to decide on which project to put my money towards. I can only really do one because I'm in college and what not. So here are the two and some info:
1980 Malibu:
So this one is pretty much done in a way and is completely custom. It was completely original and is my first car that I got when I was 14 (19 now). The hold up is that I snapped the driveshaft and it did a number on my floors which means I have to tear up my carpet to do patch work and welding. I have a feeling the TH350 transmission is done. I tried starting it the other day and it sounded like metal grinding metal and it would start so I have a feeling the torque converter and output shaft are done. At the same time, the motor has put up with a lot and is in need of a rebuild. The oil pressure dropped a few months back from 40psi to 20 and at idle barely gets 10psi. This happened after it hit 280* because the clutch on my fan went out even though it was supposed to be a straight clutch. So i figured the engine and trans need to come out and I'm going to do a rebuild on the engine as far as the cam and checking the oil pickup, which may be clogged, and a full gasket set. As for the trans, I've got one buddy who has a 700r4 core that needs a rebuild, a 4 speed b&m sport shifter, and the correct cut driveshaft that is pretty much new for 150$. This car definately needs the 4th gear being that I'm running 3.73 gears. There is other things that need to be done as far as suspension. Simply cutting a coil out of moog springs has left my lower control arms pointing upward and me having ot drive real slow over speed bumps. So drop spindles are in order as well.
1971 Plymouth Roadrunner:
The next project that I picked up a year ago, and is my second car to own, is an all original suvivor car with 100,017 miles. It was a California car brought here to texas by the second owner. The car was liened in 1977 after repairs were done to the rear passenger quarter panel. Turns out these repairs were globs of bondo so the car is getting a replacement quarter panel. Other than that the car is rust free. It has the origional exhaust, that can be reused, numbers matching 383 big block backed by a 4 speed pistol grip and 3.23 sure grip posi. The original color was curious yellow and it had magnum rims. I'm sure the shop that had the car for a while probably took them off and put the rims on it has now. Some of the other interesting options it has is air condition, manual HD drum brakes, and power steering.
Another cool little deal is the dictaphone mounted on the front console that goes with the factory AM/FM radio. For those who don't know what this is, it is a device that is plugged into the factory radio and is basically a type of recording device. It came with a microphone from the factory and was meant for doctors and lawyers. But not only does it record, it also plays cassettes through the radio. I'm sure this was meant to just play back what was recorded on the tape since music on cassettes had yet to be produced.
The plan is to rebuild most of the factory components ie alternator, wiper motor, etc. The only change I'll be doing to the engine is an aluminum intake (factory ones weigh a ton on mopar), a hemi replacement cam, and possibly headers to release the extra torque. These simple and redo-able mods bring the factory rating of 330hp and 400lb to 450hp and 500lb. Great thing about mopar. Also have an additional 4 speed the previous owner threw into the deal. Overall goal is a factory resto with minor bolt ons.
This is what the roadrunner will mainly look like when it is finished. It came with the same vinyl top and strobe stripe and I will put the spoilers on as well as a so called "dealer option".
1980 Malibu:
