Well it's been months but I took her out for a spin after the last repair. Bad juju! She sputters and stalls out at part throttle. I am wondering if I have the wrong size carb on there, if the 750 is just a bit too much and floods it out. I remember the reason I changed it was that my 600 was lean the whole time but I can just change the jetting right? On startup she has a slight misfire that goes away after warming up a bit and then she smokes fuel clouds like crazy. I am just waiting on parts for my tpi swap but until then I need it right! So anyways, do you all think I have too much carb on there right now? Mild sbc 355 running about 10.5 or 11:1, .500/.470 cam don't remember lsa, mild port work, headers, cast iron 1.94 heads, forged pistons and rods, scat crank, base timing at 12 degrees. Haven't had it dynoed since I blew the head gaskets and replaced the 2.02 heads but estimated around 370ish hp.
