Had the same problem with my 83 regal after a engine swap, the drive shaft is rubbing on the transmission hump. Take the pads off of each end of the transmission crossmember then try and find a shorter transmission mount from your local trans shop. http://youtu.be/F3SO4lP0Tpg, viewtopic.php?f=24&t=32114.
