Started them both up. Was going to load the coupe to take for alignment, but weather is going to be rain/snow mid-week. Maybe week after.
Poor wagon seems to be telling me just how worn-out it is, filled the shop with blue smoke.
Had to charge battery on the 'hoe...seems leaving the trailer harness connected let the LED on the brake controller draw it down over the last month. I miss my F350!
What myth is this in reference to
No myth, I grabbed the Shop vac from the trailer and it let me down hard. Was picking all the crap up off the floor and also found the headlight switch under the seat. Thing is junk and the original connector is nowhere to be found either.
I have a Lunati Voodoo 10120705 camshaft set a Chinese aluminum cylinder heads in a single plane intake
Sounds sweet. I was putting together my engine for a Chevette but I lost interest and bought a Regal. If if started with a Gbody I would have built a different engine. I have iron vortec heads a comp xm270h cam and the cheapest intake I could find on the internet. Should be close to 350hp at the crank(fingers crossed) would have been a monster in the "vette"
I installed the 84 buick hydroboost system today on my 78 g body. Only unplanned thing I had do was to change the steering box due to the difference s in the line fittings.
It went pretty easy for first time doing this swap. Works very well.
I have a similar 355 in my 87SS with a 270 comp flat tapped camshaft and it makes 318hp at the wheels it has EQ 180 heads you should make 350hp easily at the crankshaft
