What did you do to your non-G body project today? [2018]
I pulled my big old ugly aluminum skiff out of my yard and into the driveway. I left it last year flipped upside down so I could strip the hull and repaint. I put a couple of coats of underwater metal primer on the below-the-waterline area last week. I slowly jacked it up enough to slide the trailer out from under it. Then I lowered it down onto a couple of 4x4's on cinder blocks. I wrapped a big chain around it and used swimming pool noodles on the chain to protect the paint. Then I swung my engine hoist into position and grabbed the chain so I could lift the side of the hull up about 4 feet. I propped that side up with cinder blocks and re-positioned the chain so I could flip the whole hull over. That was when a link slipped off the hook and the hull fell back onto the cinder blocks. After I went in and changed my shorts, I used screw-links to secure the chain and this time I got the hull to flip over right side up. I wedged wood chunks under the strakes so it would not wobble on the 4x4's. Then I jacked the hull up enough to slip the trailer back under it. I carefully lowered the boat onto the trailer and made sure it was settled in exactly where it should be. Then I cleaned up all the tools, blocks, and chunks and went inside for dinner with a BIG COLD BEER! WHEW! EDIT pic
I got the Red Headed sl*t fired up and ready for a good *ss whoopin'. Took her out and gave her what for. There is a puddle on the passenger floor mat that I thought was antifreeze, but nothing more came from the heaterbox. Got a fresh tank of 93; heading to the track Friday.
I put the anti- rattle springs back on the rear drum equalizer bars (there for a reason!), drained the trans fluid, changed the clutch fluid, investigated a sticky throttle, and put on the race tires. Weather looks like *ss for Friday, but I'll be ready.
The left headlight on my Jeep was burnt out so I was going to replace it. The bulb is good, the power wire is dead. I thought about pulling the bumper cover and grill to see what is causung the dead wire but then I gave me head a shake and rethought that plan... it's just my Jeeep and I'm lazy so I spliced a wire from the good headlight to the bad headlight and got them both working.....😎
Did you check the fuses?
Reactions: Clutch
I did look and didn't see any fuses for the headlights......at least till now and looked it up, I missed the fuse panel in the lower instrument panel. #14 10 amp fuse, I'll be pissed if it is just the fuse and I went to all the extra work of splicing in that wire...
thank you
