I needed new rear springs on the GYP so I could tow a small Whaler without the rear dragging. Of course that turned into new muffler, tail pipe, hangers, brake line, and a few other things I'm not going to bother with right now. One spring came right off, one needed cutting off. All new bolts, bushings, and the axle is back in. Still need to hook up and adjust the hand brakes and bleed the brake fluid, drive shaft, and torque everything, but the worst part is over. I also welded an O2 sensor bung to the fill hole in the axle cover. That way I have a threaded fill port that will NOT leak like the crappy plastic fill plug. Filled with 75-140 synthetic gear oil for heavy duty and towing.
