Picked up a soda machine for the shop. It works and was free
Pulled the S-10 out and brought it around to the front; fired up the van and brought it around to the shop to go into winter storage. In beween took a broom to the floor and consolidated all the little piles into one bigger one. Managed to add more blobs of black goo to the psychedelic pattern on the floor; hey, it's a shop, not the Taj Mahal.
Laid out all the sections of tubing that I had cut and matched yesterday and proceeded to turn them into the basic frame for my differential dolly. The final width somehow ended up at 18-1/4", which works. Right now it is standing on end along the north wall until I can scare up some heavy square tube for the end plates and locate some wheels. I must have gotten my sums fairly close because, although I assembled the two sections independently of each other, they did slip together quite nicely during the trial final assembly. The two slip connections will be getting drilled for either bolts or quick pins as a way to avoid sudden auto disassembly syndrome.
Have to ask, how well does the sign behind the TV work? Or is that why you’re hiding it behind the tv.
Works well. My wife is so disinterested in what goes on the garage haha. She likes the end results, but is not too involved in the means to get the to the extremes 😉
Yah, it’s not that tight and there’s another door next to it for the furnace guy to get at the back so should be good. May still put one in when I replace sheet rock on the other wall to the room.
Very good. Last thing you want is to starve it for oxygen. I've had nightmares from cleaning furnace/boilers that were so carbon-ed up. Like running your engine super rich.
Reactions: Rktpwrd and Ugly1
As an extra note to my door installation. The light you see over it is a thing someone might like. It’s a hard wired motion sensor light “for a closet”. I use the garage as a pass through a lot. Gives plenty of light not to trip over things or take out a shin.
Shifted my project priority to replacing the work hutch for my Indian Project in the basement. Did some measuring and wrote up a bill of Materials for the new one and hit the Lumber yard yesterday. finished unloading the old one just after lunch today and now have an empty pocket for the new structure. This is all by way of pre-emptively upgrading this bench/hutch so it will accept the weight of the parts more easily. The original version, which had been in place for ???? was based on sawhorses from the local big box supply store but they were plastic!! and never really meant to hold that kind of load. Surprised really that they hadn't collapsed but the clock was ticking, even in a basement, U-V damage can occur and it would only have taken one inadvertent hit or knock to injure one of them. Did have one fail some time ago, the material just failed. No desire to repeat the exercise.
Tomorrow is saw deck day. Start cutting all the studs to length and assemble the feet. No woodscrews for this; 5/16ths capscrews, c/w locks and flats and 5/16ths Heavy Hex n/c nuts. If I get them done before the weather goes back to being soggy city then its progress.
Reactions: Tony1968 and Ugly1
