So im looking to build up my rear end, and im gathering up parts and i run across what a guy tells me is a gov lock. Can any body explain whats the differance from and other posi differential.
78PontiacGP said:Its almost like a trans brake instead its on the rear and puts a massive amount of stress on your gears like he said i wouldnt use that sh*t get a higher stall speed converter
Take the cover off,if you see this walk away 8)veltboy314 said:How can you tell a gov lock unit from the other units?
tc1959 said:Take the cover off,if you see this walk away 8)veltboy314 said:How can you tell a gov lock unit from the other units?
