What is the engine and what is it out of
Link
I have a sbc was told it was a lt out of a 70's ish vette the castingin the back is 3970018 and it has camel hump heads on it is anyone can help me thanks
Macguyver
SOUTHSIDE MACHINE PERFORMANCE
GBodyForum Sponsor
Mar 21, 2017
292
458
If it's 3970010 , nothing special just a smog era low compression 350. Camel hump heads are great for putting on a shelf. Do a compression check on it and if it passes, put it in your car. A 160hp 350 sure is better than a 160hp 305.
5,720
12,249
An easy 300HP, after that it gets expensive to keep those heads. A decent set of heads and a 383 kit from Skip hite and you'll be making 450 easily, but it will be at the $3500 mark with machining.
Nothing wrong with that, comes down to your budget.
lilbowtie
3,460
3,965
Canton Mi
As driven said the stamped #'s will tell the story. I think you will find the 8 is really a 0
1evilregal
3,056
4,357
Greensboro, NC
all that's corvette isn't necessarily gold... mid to late 70's corvettes only had about 190 hp from the factory... also check the casting #'s on the heads, some had "hump" castings on the front of the heads, but were often mistaken for the good ones...
