What rear suspension set up are you guys using for the street
melloelky
4,163
9,569
mass
I'm w/nailhead on this one,try and run an actual bushing in the upper ears of the differential.rubber if possible.it'll help isolate noise/vibration/harmonics better than anything else.that being said I'm running umi roto jointed upper and global west lowers.spherical bushings on the frame side of things and derlin bushings on the rear end side.these type of bushings do a great job of keeping everything in line and help with travel as the design in the rear of these cars is constantly in bind.the Roto joint/spherical bearing is prone to transmit a little through the chassis compared to a rubber bushing but the trade off is worth it.
Malibu Mike7981
Jan 13, 2018
80
200
33
New York
Thank you to everyone who replied. Im going with the umi upper adjustable with the roto joint. And the lower arms with one poly one rotor joint. Also the rear shock brace and the control arm reinforcments. New rubber bushings in the rear end housing. And a set of kyb shocks all around.
19,992
oofa
el camino ss 84
377
223
Nw okc
Both my gbodys use umi rear setups with poly bushings and then rubber bushing in the rear end ears since they will see some street driving.
