Ok, I do need to clear up one thing. The motors I mentioned are not street engines. (Even though the owners drive them on the street) Technically they are race motors. Once you pass 10:1 compression, your mild cam has a noticeable lope like a hotter cam. The Camaro and the Vette LT1 motors were basically Identical, with the exhaust being their only difference. Both at 10.0:1. The b bodies had different heads, cams, exhaust, and compression.
On the motor in question, a 350 LT1 from a '94 -'96
Caprice making a stock 260 hp with a compression ratio of 9.0:1 and torque was at 330 lb ft. With the compression of this motor raised to 10:1 and the addition a free flow exhaust, this motor will jump almost 100 hp to around 350 -360 hp with over 400 lb ft torque. A chip for the computer is needed also. This combo has been done to death. With Aluminum heads, this motor can be brought to 11:1 and higher. At 11:1, this motor with no other changes but the heads, will be above 400 hp. Torque will be close to 480 lb ft. (BTW I stand corrected, the SS
Impala did not come with the aluminum heads. The car i was thinking of had the Camaro heads put on it by a previous owner.)
The hp of the Camaro I worked on was at 285 hp stock. The addition of free flow CATs and a chip, put it over 330 hp. The car also was installed with a K&N high flow filter system and a Dynomax muffler on the stock exhaust. Then the car was pushing 400 hp. That's before I touched it. I added a 58 mm throttle body, a Hooker super comp headers and 3 1/2" Exhaust, LT4 Hot cam, 1.6:1 Pro Magnum rockers, Flowmaster muffler, a Hypertech chip, and you get the point, there's a lot in it to get the 580 it's pushing. I know there's more in it because the cam's range is 2500 - 7500 and it tappers off at 6800 rpm.
These combos are way possible when done right. The basic formula of 10:1 comp, a single plain intake, a 290 cam, ported 2.02 /1.60 heads, and a 750 carb will get you 500 hp in a 350 sbc. Heck, I got a 350 sbc with 8.5:1 comp to reach 500 hp with the right combo of parts. (It was spinning to 7200 between shifts. It was all in the custom cam and the heads)
Making 500 hp isn't a big deal, ask any race engine builder. Putting it to the ground is a big deal.
I was taught there are really only 2 ways to make hp. Cubic inches and High compression. No matter what the motor is.
That's coming from a old street racer. Which I guess I have become also since i'll be 50 this year.
T
