what should I pull off of these cars??
sawh0110
17
no particular place yet
Thanks for that idea never would have thought about doing that
sawh0110
17
awesome find! Thanks!
sawh0110
17
Anymore suggestions??
ssn696
Living in the Past
5,552
6,698
Permanent Temporary
On my 88 Firebird, the headlight doors would not go full-open/full shut. Replacement motors were many hundreds of dollars. When I opened one up, there were three plastic cylinders that are combination shock protection and sacrificial member to keep the motor and geartrain from eating itself. I cut up a hot glue stick and used the plugs to replace the crumbled plastic. Sold the car a few years later with fully functional headlight doors.
1evilregal
3,056
4,357
Greensboro, NC
I know there was a rear disc brake upgrade that used the rear calipers from an eldorado... not sure what years they are from, you can get brackets from scarebird.com... if youre looking at 98-02(?) firebird/camaro, you can use the disc brake set-up from those with some mods, the complete axle has a entirely different control arm setup that won't work in our cars.
if that granada has a 9' rear, you may want to scrounge that and find you somewhere that could make a mount set-up...
