What Should I seal this floorpan with?
Got it mostly welded in.
At first I had to be really careful that those little beads didn't fall through. As I laid down more and more beads, I found that the pan was more and more tolerant of heat. Eventually the welds took more time to penetrate so I held the trigger just a little longer. But some places didn't like that, it was a dynamic experience for sure. Once a problem area was bookended with a couple beads though it was super easy to glue it back shut. That top right corner got cut a little too sloppy so that's gonna be fun. I tried dropping little chunks of welding wire in and then zapping it to no avail. I really need something to help hold the heat. Anyone got any tricks up their sleeve they care to share here?
Reactions: joesregalproject
If you’re trying to stop it from burning through they make a heavy copper paddle on a handle to hold against the back of the weld area. But you would need a second person to hold it. Not sure if one of the other guys has a better idea.
Reactions: RabbitHoleSS
With that said, I wonder if I can't just hold a scrap of aluminum to the back side?
I believe copper has a higher melting point than aluminum. Aluminum has a very low melting point and would probably be prone to to melting and contaminating the weld.
I'm not a welder or a scientist, but that's my best guess.
But it's looking very good.
Reactions: Ugly1 and UC645
I was able to get it just by plugging away at it. I think I'm calling the inside done, now time for primer and seam sealer, in that order right?
The bottom doesn't look so hot, I didn't get good penetration (giggity!) everywhere.
Should I be welding down here too or just seal it up and send it? Should I hit the top with a flapwheel to knock it down or leave it as is?
I was still waiting for someone to say jbweld and send it 🤣
I'd hit the bottom uo to get a good clean surface, rough epoxy prime, then load the $#!+ out of it with the waxy spray coating like gm used on our frames new instead of paint, then dose it with fluid film, and send it.
Hitting it with a wire wheel , flapwheel , small grinder is a good idea. Cleaning the area for sealing and painting
If you guys are wondering how much longer I'll drag this out, my answer is this:
I did swing by the local
paint store today and got some primer.
$50 out the door, cheaper than online. Thinking I'll just brush this on, no need to get over spray all over the place. I also wiped the floor down with some acetone.
And I have 3 little spots soaking in Rust Mort again. Figure it's been this long, no reason not to try and get the rest down the way I did with the floor I cut out. Given enough time this stuff will eat every last morsel of rust. I have a tube of $10 AC Delco seam sealer arriving tomorrow and I'm curious if it's gonna be the consistency of caulk or something that's a little thicker than paint? Or could it go either way?
I'm going to prime this pan tomorrow, just want to verify a couple things: are mineral spirits and/or acetone good enough cleaners to prep the surface? And do I need to allow the primer to fully cure before laying down the seam sealer? How long should I wait to slam the carpet back in?
Go acetone or lacquer thinner.
