What to do with an ‘80 Pontiac 301
PBGBodyFan
788
1,221
Wisconsin
This person is located in my area, bought 200-4r transmissions off of me two different times. The last time he came to my house and I showed him my LeMans, he seemed excited about it and said if I ever sell it to contact him. The idea of a modified turbo 301 would be pretty cool for it, I admit, but the amount of work/money for the performance didn’t excite me as much. But would of been cool for sure.
CrammerGram69
444
146
SW, Michigan
To unfortunate people really knock on the 301 they are great engines besides the parts availability. There's also a group on Facebook especially just for those oddball engines called oddball Pontiac Motors those guys over there love those 301s.
If you're interested in selling the four barrel intake I have a friend of mine who is looking for one local to me..
10,588
14,345
I have a 1968 Firebird convertible project. Right now I have a 455 in it. A turbo 301 would be different and with gas these days make more sense. My problem is that I insist on using a set of 1967 RA/HO exhaust manifolds. With the 301 being one inch shorter deck height the manifolds may be hung too low. They may also interfere with the side-of-the-block mounted oil filter. Also the motor mount holes will require the adapters. A '68 bird is a lot lighter than an '80 TA so I think the turbo would be a decent motor choice. I would also use an MSD timing retard box and Holley Pro-jection for some modern performance. I won't know until I actually try and fit it so this is all speculation right now. But the gas problem I don't think is going away anytime soon. 20mpg vs 10 is a big difference.
SJ-400
27
36
13
Thanks and I may have to eventually part it out but I’m waiting on CK80 to see if he wants the whole engine free.
10,588
14,345
Here is a tip: the '80-'81 heads use an air injection pump to force air into the exhaust at the front of the head. Since no one ever keeps that pump the trick is to take a freeze plug and fill that hole in the head. Any '77-'81 301 freeze plug set includes the plugs that go in the holes. There are two at the firewall side that always get plugged. Just use those same plugs at the front. A good parts place that has DORMAN drawers will have a selection of freeze plugs and you can match up the two plugs you need.
  • Useful
CrammerGram69
444
146
SW, Michigan
cool beans. lmk. :)
ck80
5,743
9,123
I checked this weekend and it still turns over easily.
Great news.
If you don't mind holding it until we get a trip together up that way we'll try to work out grabbing it. It wouldn't be a last minute thing, shouldn't be a problem giving you a week or two notice before we go up that way for the wood stoves and such.
This is the expected home for it I mentioned.
Has some major paint chipping now quickly and poorly touched up from the gm primer defect on the top rear quarter surfaces, but, cleaned up ok after coming off the jack stands it's sat on for the past few years.
Question, if I've got an old tire or mini pallet or both to rest it on, would you have something that could help load it onto the rear floor of a truck?
10,588
14,345
Now I would love to see that second gen with a 301! I sometimes grab motors and even though it's a PITA dismantling and re-assembling, an engine hoist is perfect for lifting up into a truck. In my salad days two of us could lift a 301. The entire engine weighs what a bare 400 block weighs. As an official old fart, I bring a hoist.
79 GP 4 speed
448
536
Where is the motor located? I'm in north Carolina so I may be interested.
