What to do with these lines (AIR system)?
MakeMineaMonte
36
6
8
RI
So I removed the AIR system from my 86 Monte. I just can't figure out (or maybe I haven't tried hard enough) what to do with these two Lines. One was a large tube going to the air filter, and the other is a vacuum line that looks like it goes to the carb. Check out the photos. I circled the one where the two vacuum lines end up. At that spot there is also what looks like a spot for another line that isn't there... Not sure what any of that is.
ALSO! I can't seem to loosen the bolts that hold the brass fingers from the AIR system into the manifolds. Has anyone just cut these off and plugged the holes?
pontiac guy
582
843
Royse City, TX
Remove and cap that vacuum line. You can remove the large hose from the air cleaner housing. You could just leave it open. It will pull air from underhood I to the AC. Of course that looks tacky. I suggest getting an older lower half and swap it out or just weld a plug in and fill it that way. People want way too much for air cleaner housings IMO. Maybe I'm old but I won't pay more than $5 for one. I mean every car in the world had one it's not like they are rare.
Either way, that's my advice. I may have one hanging on my wall. If so I'll trade you one of mine for yours if you cover the round trip shipping. I only use the snorkels off them anyway so the extra hole doesn't phase me a bit.
Ribbedroof
4,904
7,008
Wellston, OK
I had an 83 wagon that the AIR lines were rotten on and leaking exhaust noise (pump had already been removed). Couldn't get the fittings out, so I wound up cutting the steel line flush with the fitting and MIG welding the holes shut. Was a lot better access on a 2 post lift, but I suppose it could be done either on a jackstand, or by removing the manifolds from the car.
69hurstolds
8,195
17,597
As for the air cleaner, you could take a thin piece of sheetmetal a little larger than the hole, paint it satin black or whatever needed to match the air cleaner and epoxy it on the inside of the air cleaner over the hole. Probably need to bend a slight curve into it. Unless you're wanting a more factory look like it was never ever there. Then you probably need to get a patch welded in there and refinish the entire air cleaner. Or leave the hole open. It'll look bad, but won't really hurt anything.
As far as the other lines, I'd go with Ribbedroof and his suggestion of cutting/welding them if you can't get them out.
MakeMineaMonte
36
6
8
RI
Thanks, guys. I'll remove that hose and plug it. I might eventually weld a patch in and refinish it if I paint it or anything.
