what'll it run...
beermonkey9417
2,443
12
38
des plaines, il
well i got a 78' elky with a 71' 307 sbc, stock crank, pistons and cam. 416 heads, performer intake, 1.6 roller tip rockers, hedman headers w/3" collectors, 650 cfm holley carb, th350 trans, 4.11 gears. if theres anything else ya nned to know ill post some more #'s in a bit
custom442
1,889
4
Houston
There's a lot of variables left out, but my guess is somewhere around 16-17 in a quarter. Just a guess. And it's not out of the question for that setup to go in the lower 15's depending on how well you hook up, what stall you have, what differential?, and how new (and tuned) the engine/carb is.
beermonkey9417
2,443
12
38
des plaines, il
the heads are 14014416, they have 1.84/1.55 valves, with 58cc chambers. the weight is, around 3300, and the rear is a 4.11 posi 7.5inch
beermonkey9417
2,443
12
38
des plaines, il
doubble post
megaladon6
4,006
15
Danbury, CT
don't know the heads, but i'll assume they're good and the engine is in good shape, putting out full power. i'd say 14.5-15 i seem to recall that the old chevy 307 was actually a pretty good motor
dogsht
2,003
9
36
Dayton, OH
You never said anything about the cam or compression. The headers and 4.11s will help a lot but the 307 is still small to move a good size car quick. Guesstamate 16.1 at 89mph. If it breaths has good compression and cam and decent timeing & carberation and can actually get out of the hole maybe mid 14s.
chpbstrd1
Jan 23, 2009
55
He did mention that it has stock pistons,cam and crank. 16's sounds about right anything better than that is doing well with a stock cam.
CUTLASSJESSE
197
Pecatonica,IL
my guess would be around a high to mid 15. ran my 82 cutlass a while back with carb problems...running off primarys only with a olds 350 and ran mid 17s im guessing with your tuned correctly you should see a 15
turbo78
208
billings, montana
3000 lbs.?seems alittle lighter than usual, i thinking about 16's should be a pretty decent guess.
