When to install front plate/mid
James Parkhill
21
This Is A street car. 650hp 650ft lbs 496 BBC.at what point do I need a front and mid plate. Or can I just install poly bushing motor and trans mounts....thanks.
Also th350 trans and 3800 stall.
I will get it now and again. But no track/heavy racing.
GuysMonteSS
1,449
1,541
Kentville,Nova Scotia,Canada
My 513 bb makes #'s similar to yours and all I use is the Energy Suspension poly motor & transmission mounts.
Guy
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
the only time you need to think about plates is if you have to modify the crossmember making it a problem to use the engine mounts. On our late model we ran solid mounts with a mid plate. That was so we could basically hang the transmission of the engine with just a small support on it's tail. It makes a transmission change alot easier as well
