Clone TIE Pilot said:
It's easier to change mount bushings than weld in more repair washers. Areas around bolt holes and even welds rust faster than areas that aren't joined to another piece of metal. I have seen plenty of clean panels with rust only in the welds. Joints are a weak point of any assembly. Why do you people have such such a hard on for Enegry Suspension?
It has nothing to do with what brand makes them, it's the fact that they make them properly like the originals, not just a cheap alternative.
I'm starting to think you work for Prothane the way you keep hyping them and trashing Energy...
Also the molded in inserts are a stress riser that causes the bushing to split, or when the inserts rusts out it renders the bushing hollow and no longer can do it's job, but will still look fine from the outside as it eats your frame away. Some of my old rubber bushings looked fine from the outside but were hollow on the inside because the inserts were gone, just powder and you won't know until you take it out. That won't happen with my solid Prothane bushings and if they do go bad at least I can see it without having to take them apart for inspection like a bushing with inserts would require.
Go look at some older cars (30's, 40's & 50's) when you get the chance. They didn't use collars or sleeves either and guess what? They still rusted out! Imagine that.
Like every other component of a vehicle designs constantly change and evolve. They stopped using all-rubber mounts because they fail. Period.
My car was rarely driven in the winter has hasen't seen salt in over 14 years now. I live in NJ where they only salt the roads 4 months out of the year instead of 11months like the frozen wastelands of MN. Every mount had rusty molded in inserts and a few were just gone. Other than the number 2 mount, the rest of the car is rust free. You see, the molded inserts acts like an anode which is why they rust out so quickly. The edge of the frame mount hole acts as a cathode which corrodes slower, and if you are lucky you may catch it early before there is damage. A solid poly bushing lacks an anode which reduces corrosion. An bushing with a molded in insert will have an anode which sets up corrosion.
I'll ignore the irony of somebody from New Jersey calling my state a wasteland...
So your car only had one rusty mount, yet you scream your propaganda in several threads about how flawed they are?
Since you're such a super-sleuth and concluded that the hvac drain was the cause for this already, it doesn't seem like there's any blame left to point at the mounts themselves... only the collection of debris and moisture, which is what I've been saying the entire time...
Even a group of engineers can make mistakes, cut corners, and group think that allows bad ideas to happen. G bodies have plenty of design flaws such as the poor HVAC drain that rusts out the number 2 frame mount combined with the poorly rust protected inserts, rear sway bars that cause suspension binding, flimsy frame, not enough frame crossmembers, front suspension design that is really bad by even 1950s standards, too many firewall seams that are poorly sealed, etc.
It's not down to a single group of people that make the decision and that's how it is for eternity.
These things are addressed by hundreds upon hundreds of different teams of people over decades using their research and experience to design a quality part.
Your comment about the front suspension on our g-bodies being bad by 1950's standards really shows how little you know about the progression of the automobile.
Man I just give my 2 cents and you clowns have to keep jumping down my throat, you are like a bunch of snotty highschool clicks, (some adults never outgrow highschool). Just alot of people here drinking the groupthink kool-aid I guess. Perhaps you are just butthurt that GM made a few shitty parts? But have fun lifting the body off your frame to weld in repair washers when those shitty molded in inserts you love so much turn to rust powder in 5 years and takes the frame with them!
I keep jumping on you because you're throwing around your uneducated opinions as fact, and I don't want somebody who actually wants to find the correct parts to be misled.
Right at the bottom of this page is a link to your last thread where you threw around these same statements and were met with just as much disapproval.
And I'll keep jumping on you in the future too.
There's a lot of good info on the internet, and unfortunately thanks to people like you that jump too quickly to conclusions and run their mouths, there's even more bad info.
And don't act so smug about your picture of that metal barn roof rusting at the seam.
Everybody knows that there's tar sealer in between those panels and that's what traps the moisture... and if there isn't, then the shifting panels and easily rub off their galvanized coating leading to rust.
And finally, without a sleeve or collar to act as a sacrificial anode, guess what will... The bolt!
