which pistons would work best?
Did you degree the cam straight up. did you use a degree wheel or did you possibly get the alignment of your timing chain components in an undesireable location? But you may or may not notice yhat in motor performance. I have an Isky cam with .510 lift, and a 58 cc head ,with pistons only with the reliefs.With no clearance issues. are you useing 1.6 rocker arms? Do a clay test and see if a thicker head gasket would fix your problem.
okay, stock length pushrods, 1.6 ratio rockers, heads have never been decked.
i did not degree my cam, i suppose the grind could be off,
if i were to go thicker head gasket how thick is a regular felpro to start with? i almost remember .017 when i was looking it up before, is that correct?
A .017" gasket is a shim type gasket. A composition gasket would be in the .025" - .050" range.
Before I rebuilt my 383 I was running a flat top piston with 64cc heads and a .495"//502" hyd roller cam which I didn't degree in. I was using a .041" Felpro gasket and never had a bit of piston valve clearance problem.
Since you had the heads off, put a small dab of clay on the piston and bolt the head down. No gasket and just snug it up. Borrow or buy a solid lifter to use instead of the hyd lifter. The hyd lifter won't give a true reading since it needs oil press to keep it pumped up. Slowly rotate engine by hand. Remove head and measure your clay and that will tell you what the p-v clearance is. I can't remember off the top of my head what the clearance should be.
thanks for the input guys,
im gonna order in a new rotating assembly and i will def be doing some clay tests
Why are you buying a new rotating assembly? If you reassemble your current top-end combination while only changing crank/pistons you will almost definitely have the same results. You could just put standard composition head gaskets back in and the problem would be solved. Another question: Why the 1.6 rockers? Any ratio over 1.5 is to "trick" the engine into thinking the cam is bigger (when using the stock cam) or for fine tuning after a cam swap. It also adds more stress to the valve-train. If you were installing in a new cam why didn't you just choose the grind you wanted in the first place? You will find that by stepping back to a 1.5 or 1.55 ratio you will pick up both the clearance you need and some low-end torque. Just something to consider before turning a small problem that is both cheap and easy to fix into an expensive and complicated one. Good luck and tell us how it turns out.
the 1.6 rockers came with the iron eagle heads. the guy threw in the comp cams roller tip rockers for free so i took them, i suppose at this point i would be willing to trade down to a 1.5 comp cam roller tip rocker but with the slight amount i was hitting i may try the thicker head gasket,
i wasnt running a .017 head gasket btw, i was just using a run of the mill felpro head gasket,
