which rear end?
DrRansom442 said:
El Duez said:
STL84Calais said:
sure enough, G72 the lowest ratio GM put in a car! Not for long though 😀
Will the 2.14 fit in a housing that came with a 3.08 ( GU4)?
you WANT a 2.14:1? rear gear ....there's a first!
I have 13's on my cutlass. I'd like to get the rpms down a little on the freeway.
wow now I really need to find a rear for my car ... figured I'd never be able to GIVE away that differential .... would you be intertested in a 260 V-8 too? Would really make the car move like a snail.
jonnyslick said:
pontiacgp said:
jonnyslick said:
Hey ... what is the best way to build a "budget" rear to handle say 400hp?
I'd get either of these
http://www.gbodyparts.com/product_info. ... 4fbaa6d66d
Awesome ... that's about what I'm looking for. Which one of those do you think would be the best bang for the buck for say a 400-ish HP build?
well if money is no factor the 9" is stronger
the 9" inch is stronger but heavier too...
the 9" has another avantage..they don't use c clips and although you can get c clip eliminators for the 8.5 rear end they leak so they are a waste of money...
You could probably build a 7.5 for a lot less...
~$250 for new axles...
$300-$500 for aftermarket posi, a little less for factory clutch-type...
This way you know you'd have new parts, and not ones that people have beaten up on over the years. Remember the $800+ you're paying for the 8.5" is 75% of the time a bone stock unit that's used, not rebuilt. Rebuild the 7.5" you already have with good parts and you'll be fine with 400hp.
Heck, I beat on my box-stock peg-leg 2.29 all last summer with 350+hp and didn't break anything 😉
