Despite what some in here think, it is a dangerous practice to box the rear upper control arms. Some even suggest not to use polyurethane bushings in the upper control arms. When you look at a 4 link system it's easy to see why you don't box the upper. When the rear end is tilted when your going around a corner the plane for the two ends of the upper control arm are not the same. The stock uppers twist to compensate for this. If the upper cannot twist to compensate the rear end is in a bind and will snap the rear end around, known as oversteer. Mustangs have a 4 link system and it is common problem with the upper even to put in polyurethane bushings because that will tear the box off the car. There are forums regarding this problem if you want to look them up.
here is a picture of a 4 link and it's easy to visualize how the upper would twist when the rear end in on an angle..
and here is the elongated hole from an upper on a g body that was boxed, since the upper could not compensate the bolt through the upper on the rear end side was tearing through the upper when it was binding.
