wierd issue with sbc 350
Mine all looked good too. It wasn't until I got under the car and checked the cable that I found it was slightly loose.I think it is unlikely that it is a bad module, they seem to either be good or bad most of the time. I have only once seen a car with an intermittent bad module- it was a TBI 2 liter 4 in a 1985 Buick Skyhawk wagon that had an odd habit of killing modules... Either way, it's cheap to tighten bolts first before spending money that may or may not fix the problem.
and the weekend is done so what was the problem???...he's gotta have it fixed by now... :?
sorry, been busy. beleive it or not it was the carb. the carb was used but looked to be near new, i tore it down and it was in excelent shape except there had been some gritty crap in the bowls so i cleaned it and put it back together. so finally after swapping the fuel pump and distributer for spares i had laying around i finally threw a holley 4160 that i bought for my boat and it fixed everything, well everything except my gas needle plumiting to empty everytime i drive it, lol. i am guessing that the previous owner of the carb forgot to use a fuel filter. i guess i cant complain much about the carb since i got it for 25 bucks ffom the salvage yard! i found it in the trunk of another car so i replaced my older edelbrock off of my motor with this one. the thing has got a mean second to third chirp! lol, the thing runs better with the holley then any edelbrock that i have had on it. i know i might start a debate here but i am starting to avoid edelbrock carbs anymore. i use to be a huge edelbrock fan and i have grown up with street rodders that have always used them, lately i have been seeing less and less of them and i have had nothing but issues with the last 4 i have had on motors. holley carbs from what i have read ae all around better as far as performance and the ability to fine tune them and deck them out with better parts. i am getting ready to throw my tuned port injection on the car otherwise i would be getting a new holley carb on there, my boat wants its 4 barrel installed! does anybody have any suggestions for cleaning that gritty crap out of the edelbrock? i need to clean out all of the jets and little areas, i dont want to scrap it.
It all depends on how bad it is. I once pulled an Edelbrock 600 off a Malibu wagon for $25 and thought I could fix it. It had run without an air cleaner and it had too much rust and gunk for even a soak in chem dip to clean it. If it's just a little, get 2 cans of carb cleaner and blow out all of the bleeds in it with the straw. In most cases, this fixes the problem. If you pull the jets, be careful not to strip the delicate brass they are made of. This is one of the things I did with the Malibu carb and I could never get them out.
Edelbrocks IMO are far better street carbs. Holleys are very temperamental. If you buy an Edelbrock new they work great on the street with a mild 350.
on our crate 350 and on our previous car that had a built 350 edelbrock has done good for us. i know not everyone has the same luck but there are alot of people who debate holley for edelbrock
As for the Holley Vs Edelbrock debate, I have been far more successful running an Edelbrock on the street than a Holley. Edelbrocks are the better street carb once you get the main metering circuit sorted out. Holleys are easier to tune, but unless you get one with removable air bleeds are far more limited in their tuneability. Holley's have plenty of limitations when it comes to fine tuning the part throttle cruise circuit. You can change the main jets, power valve, accelerator pump cam, accelerator pump squirter, and secondary spring-and that's about it on the basic models. Most of those things have to do with WOT and not part throttle. The Edelbrock ( Basically a Carter AFB) allows you to control the rate of change and the amount via the step up springs, metering rods and jets. Metering rods are available that have different rates of change, not just a smaller overall rod size. It is also an air valve secondary carb, which tends to be better on the street. The Holley 3310 I have on my AMC 360 always runs rich, and that's because the part throttle on that carb was originally calibrated for a Chevy 396 ( it's OEM Application). I admit, I can restrict the idle feed passage ( don't remember what it is really called) with a small piece of wire and that is supposed to fix it, but I really don't want to.
Anyhow, on the street, I am a big fan of a properly set up Quadrajet. It's hard to do correctly, but it will give the best balance of fuel economy, throttle response and performance if you really take the time to set it up. It not only has air valve secondaries like the Edelborck/Carter AFB/AVS, but you can fine tune the rate of secondary opening via an adjustable spring, so you can make the carb effectively smaller or larger depending on your needs.As with any carb, it is best tuned with a wide band oxygen sensor giving you feedback on what your changes are doing, but it can be done without one ( BTW, I don't have one).
In the end, no matter what carb you get you need to spend some time setting it up to work well with your combination. There is no bolt on carb that works it's best right out of the box with every possible engine it could be installed on. Don't just replace parts with other parts without taking the time to make what you already have work at it's best. I have always had to do this because I am poor and don't have the luxury of money to buy parts. This has taught me to learn why things do what they do and how to make them do what I want. Rather than waiting for money, I took time to take things apart, read books and internet articles and use my mind rather than my wallet to make things work their best.
i finally solved the edelbrock carb issue. the carb i got for my car i snagged from the salvage yard for 25 bucks, deal of the day consideringit looked brand new! well in this case looks can be decieving, the carb would run good and then cut out, run good, cut out...... i took it apart real fast and noticed some gritty residue in it so i cleaned it and re assembled it. problem was worse so i swapped to a holley 4160 and it fixed the problem. i needed the holley for my boat which is what i bought it for so i went and got a quadrajet, my manifold was not tapped to bolt it up. (yes i know there is a adapter) anyways i finally went and bought a carb kit for the edelbrock thinking that it may solve my issues, while looking at the kit i noticed that there were 2 cylinder shapped screen filters that sit behind the needels..... so i took the carb apart and took out the screens and sure enough they were caked with gunk. since this carb was like new, literally, no gaskets were bad so i cleaned the screens with a tooth brush and carb cleaner and through it back together. so now my car is running better then ever and more reponsive then it has ever been. moral #1 to this story, just because it is newer and looks to be good, it may not be. moral #2 RUN A FUEL FILTER. the moron that previously must have had this carb must not have been too cheap to spend 6 bucks to protect his new 250+ dollar carb and maybe put his car into the salvage yard......
Yeah, it's sad just how bad some people are when it comes to that stuff. I pulled my good Edelbrock off a 1977 Camaro for $25. The car also had a Performer intake that I snagged for $15, and it even had an underdriven crank pulley that could have been mine for $10-had I had the right socket... The carb book was on the dash, so I got that as well. I run the intake to this day on my 355, and the carb sees occasional usage whenever I need a carb that just works. I recently saw an old Edelbrock S.P.2.P. intake on a 89 Firebird, but passed on it because it is known to be worse than stock. If I had some money, I would have taken it's T-5, bellhousing, shifter, pedals, etc so I could swap them into my Cutlass. You never know what you'll find in the U pull it yards!
