Wiper Arm Adjustment?
MrSony
6,831
6,741
Des Moines, Iowa
Is there an adjustment for the park position? If so, how I do it?
O. D. Showtime
3,008
3,537
Regina Sask. Canada
There's a bracket bolted to the back of the wiper motor, on that bracket is a ball stud that the wiper linkage bolts to. This is about the only place that I could figure for adjustment.
Maybe someone else has more info..
melloelky
4,162
9,569
mass
kevin's rite,the only adjustable portion of the wiper linkage assembly is @ that ball stud.there's two nuts securing it.there's a small amount of adjustment either way.the rest of it is all riveted together.go in small increments as that arm gets closer to the sheet metal behind the booster.
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
If the wipers were parking ok before and you have not done anything with the wipers to take them out of adjustment then I don't think adjusting them is the cure.
69hurstolds
8,198
17,600
Straight out of the 85 Olds CSM:
Adjustment
If the wiper arms and blades were in the correct adjustment prior to wiper arm removal, adjustment should not be required. However, if adjustment is required, it can be performed as follows:
1. Raise the hood to gain access to wiper arms.
2. Remove the right arm and blade assembly.
NOTICE: To prevent damage to washer nozzles, temporarily remove retaining scres and move nozzles out of the way.
3. Loosen (do not remove) the transmission drive link-to-motor crank arm attaching nuts.
4. Rotate the left arm assembly on G styles and both arm assemblies on B, and E styles to a position 25 mm (1") below the blade ramp stops.
5. Tighten the attaching nuts on the transmission drive link(s) to motor crank arm 6 to 8 N-m (4 to 6 lbs. ft.).
6. On G styles, position the right arm and blade assembly 25mm (1") below the blade ramp stop and install arm assembly to transmission shaft.
  • Informative
Reactions: 5 users
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
12,177
9,779
Gainesville, Fl
Good information. My wipers park kind of cockeyed. The right side wiper rests against the stop tightly and the left side seems to park further away from the stop. I was getting ready to bend the left side arm, but I'll try to re-align it first.
Thanks for posting the information.
TURNA
Jul 24, 2009
10,941
19,992
Socialist NY
Adjustment
You just earned 2 TURNA cookies redeemable at the next NE GBody Forum meet!!
