Hi guys , I would like to know if not having a fan shroud cause my regal to overheat? i have a 307 motor and on a hot summer day i can go three miles and i can hear my radiator boiling. i dont have my temp gauges hooked up yet
Evan's 85 said:Yes, you need a shroud. Although, I don't think not having the shroud would cause it to overheat that quickly. Go to the junkyard & get a shroud off any 78-88 olds powered (307 or 260) Cutlass or Regal. Shouldn't cost more than $15-20. Also, DO NOT drive w/o a temp gauge, go to harbor freight & get a set of cheapo $15 gauges. They will have temp, oil pressure, volts all in one. Cheap insurance! If its getting hot that quick, it might need a thermostat or water pump.
palehorse78 said:hi guys revived this post cause my car is still overheating i put it down for maybe a year cause it one thing after another however i did get some things done to it i flushed the radiator,new thermostat
i had a serious vacuum leak fixed, well my mechanic noticed that i have a v6 radiator but i have a v8 motor.could this cause it to over heat?
