I am about to drop my 307 in my 86 cutlass and I don't know where to put my motor mount on the frame. The motor came out of an 87 Cadillac Brougham, so it uses the chevy motor mounts instead of the olds, and since i don't have the clamshell mounts for the olds motor, I decided to keep the chevy mounts. Where do I place the chevy mounts on the frame? Is there only one place where they will fit?
Also..... we didn't mark where all of the brackets for the belt driven accessories go... does any one have any pictures of their 307 out of the car that I can use for reference?
And on top of that... I can figure out what some of the parts in the intake manifold are...
1). I'm guessing is the PCV
2). I can't find anything in any of my parts that fits this hole. about an inch in diameter and threaded
3). some sort of vent? plastic part with a right angle for a vacumm line hook up, and a hex head on top
4). some sort of coolant sensor? it has a different plug than the normal coolant sensor that is next to the water jacket, and it is larger. i broke the plastic part of the clip on these, which is why i am replacing them.
5). same as #4
is there any difference between the egr setup on an 84 and an 87? i was given a diagram for an 84, but i can't find anything for the 87.
THANKS FOR THE HELP GUYS!! We're planning on dropping to motor in either tomorrow or thursday, so I'll post pictures of it when we're done. i'm working on a buget and i won't dare use the fuel tank that is in the car now on a fresh motor so it will be another month or so until we know if she runs.
5). same as #4
