Well guys My name is Alfonso i just joined the forum but i have been lurking around for a while and love what i see. So i decided that i would start documenting my journey on my 1982 El Camino build. Ive owned the car for about five years, and pretty much just had fun driving it. btw The front end is off of a '79 Malibu. I side swiped a couple years back and hit the rear tire of a parked 18 wheeler and i needed to get it fixed so a friend found the front end for me so i threw it on... but that will change because im going back to '82 header panel. But anyways now im ready to make it look real nice and unique with a couple of tricks up my sleeve to hopefully make it stand out here in good ole Houston, TX. So here's my build 8) ....
btw these pictures are a couple of months old but i'll load more later on tonight of the current progress of where im at:
i had already started to sand down the bed of Elco and removed all of Conquista side trims and ground down all the studs
here i started doing the body work on the bed and many hours of block sanding to get the car laser straight in case i decide to to go with a dark color. I had already done the body work on what seemed like a hundred trim studs.
