Well I had the The LM7 Vortec 5300 5.3 in mind, Is that all that has to be modified?monte olrac said:
Conan-64 said:You will also have to modify the oil pan as well. or use an oil pan from an 98-02 F-body. The 5.3 vortec will hang down about 3" to low once installed.
Conan-64 said:i'm currently in the middle of doing this swap myself. I found a great deal of info on LS1Tech.com. I'm about 2weeks out from actually doing the complete install.
is there any reason you preffer Carb over fuel inj?
bigtrent said:figured i'd throw my newb 2 cents in here. believe all you will need is the computer and a plug and play wiring harness. as well as an in tank fuel pump for the higher pressure that the FI requires.
