Steering box upgrade, options?
flatheadfever
42
Nova Scotia
I want to up grade my 83 LeMans wagon steering box. What are the the cheapest options?
I have a clip from a 77 trans am, will this steering box work?
I am new to this.
Should I look for a z28 box or a SS Monte box?
Does it have to be metric?
pontiacgp
blank
Mar 31, 2006
29,270
20,419
Kitchener, Ontario
Z28 box has shorter stops and a heavier feel than the SS box, both have the same ratios
I use a Z box since it stops the tire rub on the 36 mm sway bar I use. U turns are not as tight but I'm fine with that
Possumz
129
Virginia Beach, Virginia
I :bump: use a Z box since it stops the tire rub on the 36 mm sway bar I use. U turns are not as tight but I'm fine with that
flatheadfever
42
Nova Scotia
What year Z boxes can I look for?
Freddiesmooth
22
Pittsfield Ma
Use a steeing box from a 82-92 camaro or firebird . they are 2 1/2 turns lock to lock with no internal stops so you will have full swing unlike the old style z28 box . My box was taken from a 1988 formula 350 firebird and it works perfect
billyjack
468
56
Western PA
Another possibility that is often overlooked is the Buick Regal. If you see one in a boneyard with a rear sway bar, it will have the good steering box, exactly the same pieces as a T-Type or GN. If you find one, take the pump also, since the high-effort box has sightly different pump valving.
Bill
pontiacgp
blank
Mar 31, 2006
29,270
20,419
Kitchener, Ontario
billyjack said:
take the pump also, since the high-effort box has sightly different pump valving.Bill
I always thought all the pumps were the same...interesting and now I'm wondering about my pump..
pontiacgp
blank
Mar 31, 2006
29,270
20,419
Kitchener, Ontario
I really appreciate that info and I bookmarked that page...I'll be looking into that this week..
