G-Body_Vet said:
I'm not looking to start a pissing match over this or discredit what you're saying, but there's write-ups about this swap on almost every g-body website. So do tell more!
The reason most sites tell you its the greatest thing since sliced bread is these boxes rarely, if ever, fail. I happened to be one of the few (un)lucky ones that had a box with a broken internal stop. Naturally I took it apart to find out why.
If you choose to go with an f body box it'd be a smart thing to weld an external stop on at least the right lower control arm where it comes on full lock. Reason being, as I said before, is the left turn is controlled by the end cap. You can gain the full left turn ratio (which would be 39 degrees on our g-body) by swapping end caps. But the right is controlled by a spring/ring mechanism internal to the box and cannot be changed. However there may be modified end caps or internal springs available from aftermarket companies that govern both stops, youd have to call around and ask. and by that point couldve just bought a monte ss box.
gbody enthusiast backs me up here ->
G_Body_Enthusiast said:
the g body ones have 39 degree stops, the fbody ones have 32 and 35 degree stops
35x2=70 degree turning radius on the box, most fbodies are 70 degree i have found. 64 degree is even worse no wonder some people can't make a u turn :shock:
and most f body cars are 2.75-3 turns lock to lock, the higher performance versions are 2.5 turns. I have always heard of this 2.25 box but have personally never seen it or known anyone with it beyond aftermarket
ponitacgp is spot on here
pontiacgp said:
The bump steer isn't affected if you use the G body pitman arm.
use a monte ss or gn or 442 box from a g body and you'll never need to second guess, if you want an easier steering feel then upgrade the pump :!:
