pencero said:I can't believe everyone turned it into a chevy vs olds argument once again. I'm not the most mechanically skilled guy on the board. Two engines I am looking at getting eventually are the LT1 from early 90s Buick Roadmaster or the 5.3 LS1 from several different makes/models. I would suggest you look at the same two engines if you want an engine that is more 'plug and play'
Ha ha you can't believe people turned it into a Chevy vs. Olds question, it's the Olds section and the guy has an Olds with an Olds motor currently, you admit you're "not the most mechanically skilled guy on the board", and you suggest possibly the LEAST plug-and-play Chevy solutions? You might want to look at an Olds motor too...
