idk what yall are even talking about anymore. To the OP however, the next thing you need to do is see what flies and what doesn't w/ your local smog and local dmv. Different dmv's are stricter than other 1's. I was already out in cali with the cutlass and went through all this bs already. The only engine I saw people using in cutlasses were 307 olds or 350 olds. They said if you try to use any other engine you will just get turned around and not be able to get plates. If you do use the 350 olds it would be better to set it up stock, slide through and get plates, THEN pull it back out and do the intake/carb you would actually like to have fun using on a daily basis but just roll up stock and it can't look like a shade tree mechanic did the work b/c you might find yourself at a really strict dmv saying that 'the engine came this way' and 'should be stock' playing dumb to a smog nazi. If they find out its not the original engine nazis will march out with trumpets playing so loud that whatever you have to say is being drowned out. I had my cutlass out there for like 60 days and gave up on doing anything but some interior work real fast. It quickly became clear that even with the stock setup I was going to pass/fail the smog test by a hair on either side b/c my car was right on the fence and my engine had under 100,000 miles...
