Rear diff gear pattern
Collector
Aug 28, 2011
61
17
8
Hoofddorp,Netherlands,Europe
Question for the diff specialists:
Gm 7.5" Rear diff with a 10 bolt cover.
New ring and pinion, pinion backlash is at 0.010 inch, got the right pinon (15 inch/lbs) and carrier preload.
Pinion has the standard shim which is 0.35"
Backlash Is a tad loose and needs to be a little tighter with another shim, most important for me right now is the gear pattern.
I think i am real close, on the other hand there are people who do this for a living and i am sure they can give me some advice or at least point me in the right direction.
pontiacgp
blank
Mar 31, 2006
29,270
20,397
Kitchener, Ontario
I would bring the backlash down to 8 and check the pattern again. The pattern you have now looks pretty good.
Collector
Aug 28, 2011
61
17
8
I knew backlash is a bit loose so i will go and try to get it towards the .008 and see what happens, might take a while before i come back with pictures time is a bit short here.
Fox80
563
9
16
Jamestown NY
Get a pinion depth tool and set it correctly, the "yellow goo" is a guess at best
Bonnewagon
Lost in the Labyrinth
10,569
14,312
Queens, NY
Any factory manual that covers rear wheel drive has a section on tooth contact pattern. It will have examples of patterns and tell you what to do to correct them.
Collector
Aug 28, 2011
61
17
8
You're so true on that, those patterns are all over the place,( and yes i have 2 books on the monte carlo) but... they don't tell you how to tweak a little like the guys do who have done diffs for a long time.
I am an instructor in pneumatic door systems,(especially train doors) and believe me, you can adjust a pneumatic door from the book, or take some instructions from me, i guess i can teach you faster how to do it then the book does.
And thats why i am asking here so the experts can give me some tips and hints on the matter, after all its my first time doing a rear diff.
UMI Sales
GBodyForum Sponsor
Oct 11, 2011
540
1,007
Philipsburg, Pa
We set up our own axles in-house using the pinion depth and backlash readings combined with reading the contact pattern and a certain amount of precision guesswork.
I agree with GP. And the fact that you're even checking it with tools and also with pattern paint is more than many installers do...
FWIW our Green Machine uses the factory 7.5 housing, Moser axles, Motive Gears set to 0.008, pinion depth adjusted to etching on pinion, Auburn Road Race posi and a Moser cover. All is well so far.
Collector
Aug 28, 2011
61
17
8
Thanks for understanding, i will bring back the backlash to .008 i have bought the necessary tools to do the job right.
Even bought the beam type inch pounds torque wrench,and a dial gauge with a magnetic base, those tools are a must have for this kind of jobs and if treated nicely will last a lifetime and then some.
Click type torque wrenches for ring gear bolts and bearing caps from work and even the diff oil is from my work as they do gear cases for trains. (Shell Spirax S4 AT 75W-90) And believe me nothing but the best as those gear cases do a million km and the oil has to last for 15 years before its renewed
I have a nasty habit of wanting to try to do things myself, i have a broad mechanical background so wrenches are no strangers for me.
Only sometimes its best to ask the guys who know, so i don't F up some expensive gears.
I am using a standard rear diff (GM 7.5") from a chevy monte carlo, this spare diff was junk.
I have a TH200-4r that has to go under the MC to improve mileage.
Downside was i needed a different gear setup on the diff, this is just a cruiser not a race car.
So i am overhauling the rear junk diff with new bearings and seals, 3.42 gears to make the most benefit of the TH200-4r.
Bonnewagon
10,569
14,312
Queens, NY
Understood, I am also a DUI nut. Anyway, listen to UMI and start with the correct specs for new gears. And IF that doesn't get a good contact pattern, then feel free to experiment a bit. But there is no magic formula aside from changing the pinion depth and backlash since every set of gears is different and a matched set. The book covers that. Even then you might find a "+" or "-" on the pinion to indicate that the factory wants a bit more or less depth for that particular set. I know a guy who does gears for a living and he uses ONLY tooth contact pattern to set them up and HE can tweak it without thinking twice about it. I don't think anyone here is that proficient, least of all me.
