MALIBU Latest Project
Peter Gray
15
51
13
British Columbia
My first attempt to start a "new thread" and at the same time introduce myself. I recently purchased a completely stock 81 Malibu Classic coupe. I believe I am either the second or third owner. The car has 93,600 km showing on the odometer. Absolutely zero rust but both the headliner and cracked dash pad need to be replaced/refurbished. So far I have replaced the 267 SBC/350c powertrain with a new LS 5.3L/4l65e setup, added dropped spindles, 17" US Mag wheels and BFG tires.
Reactions: 15 users
19,992
Nice looking Landau!!
clean8485
2,862
2,154
Ontario, Canada
Welcome to the site! Lots of good people and info here. Nice looking Malibu! Looks and sounds like you've made a good start on it already. What brand of parts did you use to do your LS conversion?
12,177
9,779
Welcome to the forum, Peter.
That is one clean looking Malibu. Great platform for an LS swap. I like the wheels, too.
7,989
18,697
Welcome to the site from Houston. Great looking car!
Peter Gray
15
51
13
British Columbia
The parts that I used for this LS conversion are as follows:
Engine - a 2004 LS 5.3L Cast Iron Block, Comps Cam and Bee Hive Springs
Transmission - 2004 4L60e rebuilt to 4L65e specs. G Force crossmember. The stock GM TR Sensor on the side of transmission provides P & N Safety switch plus back light control. I used the Holley Front Accessory Drive System, Corvette water pump and harmonic balance. I used the Holley oil pan and the fit is perfect!
Throttle is Drive by Wire (truck pedal and TAC module). Rather than modify a GM LS wiring harness, I bit the bullet and purchased a Painless Harness. The ECM is a Blue Green 411 model. I have a friend who has HP Tuner on his laptop and he did the re-programming of the ECM.
I kept the stock clam shell motor mounts and used Dirty Dingo sliding motor mount plates. I also am using the Dirty Dingo mounting bracket for the ECM. For exhaust, I skipped using headers and instead used the GM LS3 crate motor cast manifolds. The passenger side manifold dumps very close to the frame, so I may have to do some slight modifications. On the driver's side I will be getting rid of the stock brake master cylinder and proportioning valve and replace it with a Wilwood setup. The aluminum radiator is from Northern Radiator as well as the dual electric fan shroud. The car did not have factory AC so I am going to leave it as is.
My next challenge - replace the stock 7.5" non-posi diff and 2.29:1 gears. I am searching for a set of 3:42 gears and a posi.
Hope I have answered your question - thanks for your words of encouragement too!
Turbolq4
1,732
4,207
Nampa Idaho
It's going to be a whole different animal!!
My 81 crew cab (four door) had the same puke engine and a th200. It's a little more energetic now.
Welcome to the madness from Southwest Idaho!
