1983 Oldsmobile Cutlass Supreme Sedan LS Turbo Build
You going to stick with a stock intake with the bigger turbo?
I have a TBSS intake I will put on it next year. I want/like the torque from these stock ones.
Slowly picking away at this overhaul!!
Sweet stainless merge by Ace Race Part:
Trying to get better with this stainless TIG welding; it is NOT easy:
Drivers side set up:
PS manifold done:
Will keep on, keeping on!
Had to fill a gap due to imperfect fitment:
Worked out pretty good!
Been awhile since I've looked into your build. Moving along nicely 👌
Been doing my honey-do projects after LS Fest. Haven't driven the car in 6 months! 😢
But thank you!
  • Dislike
Reactions: 64nailhead
Haha - honey do lists are the worst when the car is in pieces 😉
Glad to see you’re back into it.
Reactions: GroceryGetter83
Still haven’t driven the car! It’s been over a year!!
But making some headway recently.
Transmission has been rebuilt/refreshed:
Now has a 36 element sprag, billet intermediate shaft, new Hipster billet valve body, HD case and dump valve added.
Added FID 1300 injectors, Holley fuel rail, TBSS intake and Snakeeater 92 mm throttle body:
Next items are fuel system plumbing and cold side fabrication.
