What did you do to your g-body today 2025 Edition!
Installed the quadraje tv throttle arm kit for a 200r4 for a 70's q jet and rigged up a bracket using lockar cables for both throttle and detent. Both clear and looks like it's gonna work. Still need to set the adjustment.
What was your source for the parts?
More tools, pneumatic jackView attachment 251244
i have one, it takes about 10 secs, to lift my Monte. Don't look at the cob webs LOL.
mclellan83 that Edelbrock is a nice display
Thanks, its actually just a phone that hooks up through bluetooth. Still debating on buying yet another head unit to be able to run my stuff the way I originally wanted and being able to do away with the phone
Monte Carlo - new engine (well new to me) is being installed
Regal - pulled out the single din for a single din floating unit. Installed a Wolfbox rearview mirror with dual cameras. Hoping to finish the control arms next week.
Fixed (more like finished because I forgot to weld it fully) the passenger side muffler, dusted it off and took it out of its tarp prison
Supposed to be really nice tomorrow, so I figured I’d drive it once or twice before I ripped it apart again. Made some changes to the carb over the winter that fixed a stumble at low speeds, but can’t check how rich or lean it is at cruise since the wideband sensor croaked.
Also got my spindles back from Mr. Degeer, put an order for a hub bearing to test fit the C7 brakes to tomorrow. Hopefully they fit, I want this thing done for G-Body Classic.
