10 bolt 3 series posi unit. Will it fit?
Zone_4_Lanlord
Feb 14, 2010
Philadelphia, Mississippi
Today I found a GM 7.5 10 BOLT AUBURN 28 SPLINE 3 SERIES POSI UNIT for cheap. I know I need 28 spine axles. My question is will it fit my rear no problem, I'm not really sure what gear ratio the car has now, but the engine was origanlly a 3.8. I also plan on buying 373 gears if it all works out. This car is on street tires and will never see any track time.
Zone_4_Lanlord
Feb 14, 2010
Part #: A102810 (1-Pair)
Mfg: GM
Model: Cutlass, El Camino, Grand Prix, Monte Carlo, Regal
Year: 1982, 1983, 1984, 1985, 1986, 1987
Rear End: 10-Bolt 7.5" & 7.625"
Spline Count: 28
Length: 28 7/16" long,
Bolt Pattern(s): (2) 5 x 4 ¾” (.505” Knurl press
These are the axles I plan on getting. Is this the correct length
20,413
It can't be a 7.5 if it has 28 spline side gears...it'd have to be a 7 5/8 or an 8.5 to have 28 spline side gears
Zone_4_Lanlord
Feb 14, 2010
The add said 7.5, I think it came out of a 90s camero
jimmyp618
136
Itll work , I have one in my elcamino with 28 spline G/N axles.
Zone_4_Lanlord
Feb 14, 2010
Another guy tells me I might need C clip elimintors, is this true? What is the purpose of this?
20,413
then the add is wrong if it said it had 28 spline side gears
Zone_4_Lanlord
Feb 14, 2010
I don't understand. Are you saying it will not work ?
Let me explain better the unit that's for sale is a posi 7.5 3series auburn, that accepts 28 spine axles. my question is can I buy grand national axles 373 gears and throw this in my bonneville ?
Doug213xrj
1,529
131
West Michigan
Weather its a 7.5 or a 7 5/8 it will bolt in your 7.5 rear housing. If its 26 spline axles then you don`t need axles, If its 28 spline axles then you need 28 spline axles.
Doug
20,413
there never was a 7.5 that had 28 spline axles...I'm not saying it won't work but the guy should know what he is selling. For all you know it may be an 8.5 which wouldn't work in a 7.5 housing
