10 second Monte for sale - cheap!
I got my Regal to just over 3200# w/ driver w/o too much problem. As far as cage cert, it isn't required until you go 9.99 or faster. Here is an article they did on my friends car a while back.
Curt Connors’ 9 second carbureted LS1 Monte Carlo​
Curt Connors and his family are well known around the Mid Michigan Motorplex. They are die- hard bracket racers that make the weekend a family event. Curt’s wife Melissa and his parents all spend the weekends at the track most of the summer.
Curt’s 84 Monte Carlo is back halved, with a Mild Steel Cage. The Dana 60 houses 4.56 gears spinning 14×32 Goodyears. The car is all steel except for the hood and decklid, with stock glass throughout, but Curt has managed to get the weight down around 2700lbs. Just right for the Transmission Specialties Powerglide and 8” race converter to do their jobs.
The engine combo is a straightforward setup. It is 403 CID, based on a 6.0L LS1 truck engine. The stroker kit consists of 4” stroke Callies Compstar crank and 6.125 rods, and Autotec flat top pistons. Final compression ratio is a hair over 13 to 1. The heads are CNC Ported RHS units from Competition Components, with 230CC Intake runners, 2.080/1.600 stainless valves, and optional solid roller springs. The cam is a custom solid roller, with 260ish duration, and .750 lift. Lunati roller lifters and Trend heavy wall 5/16 pushrods make sure all of the cam’s lift gets to the T&D 1.7 ratio rockers. The engine is topped off with a hand ported Edelbrock Super Victor intake and a Holley 950 gas carb. The stock LS coil packs are run by an MSD timing controller. Headers are modified Schoenfeld Circle track headers, that were coated at QC Coatings in Utica, MI.
Curt’s first time out with the new combo was at the final test and tune day in 2012. Baseline passes were in the 9.80’s @ almost 138MPH. There wasn’t any time for any real tuning, just a few shakedown runs. For those first few hits, Launch was 5200RPM, and shift points were 6700. For next season, Curt has a new converter from Lenny at Ultimate Converters in the works, as well as some other refinements in the works. We are as excited as Curt to really put this combo to the test during the 2013 season. Stay tuned for more results!
On Board Video:
I called BS with the 3.73 open rear and the lost the title claim.
If it isn't listed as stolen, then that's only because the owner isn't aware or doesn't care that it's missing.
Went to the shop that a local guy has that run in those street outlaws shows by invite. He pressed in some wheel studs for me and showed me what he has in two car trailers in the parking lot. A Monza BBC Chevy and an huge ci 86 Monte. Both cars although you can tell multiple guys have put lots of expensive parts throughout the years are well built. He claims to only be able to get a few thousand $ if that much from the series to run, claims he never makes enough to go even close to making any $ after gas expenses for his truck and crew of 2 other guys. He told me that the regular guys make money and parts supplied to keep running and that most of the show is staged and that he is not going to run anymore cause it's a setup every time and the stars of the show are a bunch of jerks. "Reality" at its best!
