Well if that's the case, then how's it sound to splice 4 - 16 gauge trigger wires to an add-a-fuse with a 14 gauge wire and a 10 amp fuse?Yup, trigger wire can even be a 16 or 18, not much load there.
Just trying to weigh my options
That fuse box is fused so I wouldn't add anything inline. Find an open blade out, wire into that one and fuse that one in the factory box.Well if that's the case, then how's it sound to splice 4 - 16 gauge trigger wires to an add-a-fuse with a 14 gauge wire and a 10 amp fuse?
Sorry im not following this last part.and fuse that one in the factory box.
Yup. What I mean by that part is in the factory fuse Box, basically find a terminal that is going out. You have 2 terminals on a fuse blade, in which is coming from the Ignition circuit on the car, and out which is going to whatever. Take that out and splice your trigger wires to that. Then its already fused without adding anything extra.Sorry im not following this last part.
Factory fuse block is fused, do not add an inline fuse on trigger wires. Got it. So i can tap direct to factory fuse block and do not add a fuse, right?
Ok got it, thanks for the help. Was basically what I was thinking but just wanted to make sure it was correct.Yup. What I mean by that part is in the factory fuse Box, basically find a terminal that is going out. You have 2 terminals on a fuse blade, in which is coming from the Ignition circuit on the car, and out which is going to whatever. Take that out and splice your trigger wires to that. Then its already fused without adding anything extra.
Basically you're looking for an open fuse in the fuse box you can use.
Yeah, I know what I said earlier was a little bit confusing but then I started thinking about it, you can just add to the factory Box without having to add anything extra.Ok got it, thanks for the help. Was basically what I was thinking but just wanted to make sure it was correct.
No problem. I got the splice idea from the factory harness which has a main wire splice on the pass valve cover area, one going to alternator and one going to starter I believeYeah, I know what I said earlier was a little bit confusing but then I started thinking about it, you can just add to the factory Box without having to add anything extra
