??If it will support what you are doing and not interfere with anything else.
All i know is it’s hot with key-on per myNot sure what I said was vague... you want to use a random 12v wire without knowing what else it may go to.
Awesome, thank you. I will confirm tonight when I get home.The brown power wire at the oil pressure switch goes to fuse number 2 top row on the right. Goes through a 20 amp fuse to the 12GA orange wire on the ignition switch, this circuit also powers fuse 4 and 6.
Pull the fuse and see if the wire goes dead, then you know what circuit you are using.
Yes you understand correctly. Thanks for the great information. So did fuse #2 only protect the oil pressure switch wire or are there others as well?If I understand correctly this is being used for the control side of the relays. Bosch relays draw about 150mA to energize the coil. Running 4 relays will not draw a full amp of current. The circuit will have lots of excess capacity.
If all you run off this circuit is the 4 relays I would change the fuse to a 5 amp or smaller.
Ok awesome. I will verify tonight. I looked for this a while back in my haynes but they did not have it.On the diagram I have the #2 fuse only powers the electric choke there is nothing else on the circuit.
