Boy we off on tangents, don't we? :lol:
Most of what is posted is true about the 301 Vs traditional Pontiac. The short version is the block is "basically" the same dimension wise, just shorter deck.
Intake is 265/301 only.
Tradional heads and 301 will interchange but would require a custom intake due to the deck hight making the valley wider or narrower.
I have built and raced both 301 and traditional. I am T1000 301 on this board, read away:
http://www.301garage.com/forum/index.ph ... 56#msg3256
Oil pans, timing covers,pullys, timing chains/gears/hardware, camshaft,lifters, rockers, studs,windage tray,oil pump, fuel pumps,most brackets and exhaust manifold can be exchanged.
gto78, I had a diehard chevy guy working for me that was almost pissed that the lowly 301 came from the factory with screw in studs!!
I talked to the tribal high council and they decided that you will not be banished. I told them you have much wisedom installing a proper engine in your car instead of a little orange one!
