I know I asked this before but I have more information this time so I'm wondering what kinda hp I'll have
Specs:
350 olds .030 over
Speed rpo forged pistons with 2 valve reliefs
#5 heads 3 angle valve job shaved and big block valves
307 bronzed lined connecting rods (for nitrous)
Stock polished crank
Edelbrock performer rpm intake
I believe patronix street or strip distributor
High volume aluminum milo den water pump
High volume oil pump
Comp valve springs
Comp roller tip rockers 1.6 or 1.7 ratio bigger studs
Comp cam .520/.523 lift 274/286 duration
Block decked
Flowtech headers 1 5/8 primary tubes and 3" collectors
750 cfm carb
March serpentine system
3" dual exhaust with x pipe and cutouts no cats
Summit pro torque mini starter
And a 75hp shot of nitrous (probably only use once or twice a year)
I'm pretty sure that's it I'll update if I remember anything
11:1 compression
Specs:
350 olds .030 over
Comp valve springs
Block decked
750 cfm carb
11:1 compression
