Thanks. The 70 definitely needs the 225/70R14 in those wide wheel wells. I wish Olds would have gone to a 15" on the 1987/88 cars these rims came factory on.Those wheels look great on there!
You got bit! Lol it's funny when someone else does itI checked the timing was around 14 degrees at idle bumped it to 20. It ran better but then I remember I left the vacuum advance unplugged and blocked off. I open the hood to a tiny fire! The coil wire popped off and was arcing and caught the boot on fire! I got it out and went home, almost there. It was even more responsive with it hooked up. I taped on the coil wire, yikes!
Is that like seafoam ?I decided to do a compression test on the 350. Of course I had to buy a new one, the thieves stole it during the break in. Last time with the 55cc heads and the 204/214 cam 9.6 to 1 compression, 160 to 175. Tonight, 1-150, 3-150, 5-145, 7-110, well crap, number 7. 2-150, 4-155, 6-155, 8-110, WTF #8! I added oil to #8, 150. I added oil to #7 and 130. A bit disappointed at 7 and 8. It is a 9 to 1 Olds 350 with a 214/214 cam degreed in. It is a 43 year old bottom end, brand "C" wouldn't be near as good. I will get a hold of some more Keenflo combustion chamber cleaner. I gained 20 to 30 psi on my last Olds 350 by soaking the cylinders overnight.
No I put some of the similar Motormaster Seafoam stuff in those holes last night. I also use the STP in the similar can. Seafoam did squat on my last 350. It is stinky stuff, dissolves carbon and crud if it has sit time. I believe it is a Canadian company. I believe it is toxic stuff and therefore hard to find now.Is that like seafoam ?
