Got the drive shaft in, yoke about half way in the output shaft with the rear control on stands. Fully extended would pull it in another inch at least. I had to modify the the little driveshaft loop near the front U joint. Added carriage bolts and added spacers, should just be clear of the larger 1350 yoke. The battery was dead. Have the charger on, will need to hook up the laptop to enable the 4L80E. I put in about 10 liters to start of some THF and synthetic Dexron 3.
