1980 Grand Prix LS swap
Winkernod
139
259
London Ontario
So before I installed the engine I thought I would be smart and try to make more clearance for the HVAC box and modified the mount for the coils. It did help but not enough to warrant the work.
Winkernod
139
259
London Ontario
Fun day!! Engine goes in. lots of clearance for the PS box but not even a 1/4 inch for the HVAC. I felt that was way too close so then I pulled the engine out and pulled the mounts and elongated the holes forward about a 1/4 inch. dropped the engine back in with much better clearance. I did end up with a 1 inch crack in the housing.
Winkernod
139
259
London Ontario
Next major step was to do the fuel. dropped the tank and this is where I really realized how clean this car was I did the full meal deal with the tank, sending unit and in tank pump
GroceryGetter83
LS Mafia
676
2,406
Tampa, Florida
Which sending unit did you purchase?
Winkernod
139
259
London Ontario
The Holley transmission crossmember and adapter pieces was an interesting hour as I could not find any well done instructions, but finally got it so it fit and worked.
Winkernod
139
259
London Ontario
I guess this would be a good spot to give a list of parts used
Holley Parts:
302-2 oilpan
7122104 clamshells
12643 LS engine mount
71221015 engine mount
12644 trans crossmember
12655 mount bracket
12647 trans mount
8501 exhaust manifolds
70701317R LS swap adapter pipes
SPI fuel tank
GM 306C fuel tank
FG156A sending unit
255 aftermarket fuel pump (walbro knockoff)
6AN fittings and nylon braided HP hose (amazon)
cooling
CU162 spi aluminum rad
C71324 Lower rad hose (88-91 Dakota 3.9L as best I can tell) trimmed as needed on both ends
12551708 3 wire coolant sensor
Amazon
85668 4 circuit fuse block
5 pin 30/40 amp relays with pigtails
wiring loom harness adhesive fabric tape
misc 6AN fittings
Winkernod
139
259
London Ontario
All though this build wiring wiring wiring!! Every time i went out to work on the car I tried to do at least one thing electrical so that it wasn't too intimidating. Most wasn't too bad. I am building this car to be a good reliable turnkey summer cruiser that anyone can drive. So with that said I didn't need to go heavy duty on the cooling. so just an SPI rad, trimmed down the fan shroud to mount it with ( for now, I will watch if it is not solid enough), 2001 Concorde dual 6 blade fans setup with the fans setup to come on one at a time controlled by the ECM.
Winkernod
139
259
London Ontario
Working on the exhaust was in interesting adventure. First pic is baking a rattle can coating on the manifolds (kinda an experiment to see how good this stuff is) I installed the manifolds on the car then went to put the adapter pipes on and could not get the bolts started well then got one to start and put a socket on it and got real tight real fast so took the manifolds off and found that the holes were tapped with M9x1.5 but the bolts were a M10x1.5 . I then ran the M10 tap though with no troubles so the hole was drilled to proper size but not tapped to correct size. With that looked after put manifolds back on and put the right hand adapter pipe on and put a small cat on it and it all lined up beautifully. The left side was not as as fun. it did not line up with the notches in the cross member and did not allow clearance with the cross shaft for the column shifter. I called Holley and talked with them only to realize there was a disclaimer that there are some fitment issues. So i have just finished giving the pipe a little nip and tuck but haven't installed it yet
Winkernod
139
259
London Ontario
I think that brings me up to date. Next moves are to finish the trans cooler lines, block the hole in the intake where the EGR pipe went in, get the driveshaft shortened, pick up the new tires, sandblast and paint rims,
